- Nov 9, 2005
- 26
- 0
- 0
i bought a complete system from Koolance with 10mm ID
everything is ok, except the waterblock for cooling SB chip, the CHC-125
here is the picture
http://www.koolance.com/water-...es/more/chc-125_p2.jpg
as you can see, it has a 360 rotational sockets, but the ID of the socket is only 6.5mm
the rest of the blocks, CPU, NB, GPU, HD, all have 10mm ID nozzles
how will that block CHC-125 affect my flow rate?
i have their exos-2.5 external system, CPU block, GPU, SB,NB, 2 HD blocks and all the
nozzles are 3/8" 10mm ID, and the tubing is 3/8' ID.
how should i design the loops? shall i just go with single loop? what is the ideal loop order?
thanks so much
here is the picture
thanks so much
