- May 3, 2004
- 126
- 0
- 0
Hey!
I'm going to start watercoolign again and I'm curious if I MUST use a block designed for the Athlon64 because they are pretty pricy.
I want to keep the whole setup under 120 bucks so I was thinking of the following
Via Aqua 1300 - 25 shipped
Heatercore 86 chevette - 20 at autozone
metal for a shroud or various duct tape methods? heh - 5 bucks
CPU block?!? I was thinking about a -25 dollar spiral heatsink for socket a but not sure it would work
VGA block.. dunno.. want something cheap that does alright
I don't have the standard socket a holes but is there a hold down that will work on A64 Mobos for the socket blocks. Would it really be worth it?
My video card is a sapphire oem 9800pro
Thanks for any hints/tips on parts or suggestions.
