Costas Athan
Is it easy to give links to the parts you used? I can't find them on Koolance's website...
Vapor comes from water. Water evaporates more rapidly as its temperature rises and when the temperature reaches its boiling point vapors leave violently the body of the water.
Water cooling loops do not (or rather... should not) get that hot. In my experience, I've noticed that most acrylic containers (i.e. your reservoir) only support water up to about 50C, so you'd run into issues long before vapor becomes a problem. This is really a non-issue.
Vapor builds even at room temperature, but in a slow rate. So yes, probably it won't be an issue, at least not a serious one, for PC water cooling with these "low" temperatures.
vapor isn't going to keep going up. The amount of air in your loop is fairly fixed. Some water molecules will evaporate (vaporize) and then those water molecules will hang out in the fixed amount of air in your closed loop. Eventually, more water molecules will evaporate. But, they can't enter the small amount of fixed air because the gaps are filled by the vaporized water already there! (at fixed pressure, that is. You aren't going to be running increasing PSI in your closed loop) So when the air in your loop is saturated with water vapor, the amount of vapor in your loop will not increase, as evaporating water replaces the water vapor already in the loop, with the displaced water vapor becoming liquid again.
is cheaper... does the exact same function as u are wishing for... and on top looks BLING!
