Water coolers - How is your circuit set up?
Mrvile
14,066
I've got mine set up as -
Resevoir -> pump -> rad -> CPU block -> back to res.
Meaning I've got a lot of hot water going through my loop, is this safe?
NINaudio
526
4
It's fine. Order of components usually makes very little difference in temps. My system goes:
pump > CPU > GPU > chipset > radiator > res > pump
Jen
24,206
14
what you have will work fine
compudog
5,782
Best way (IMHO) is res>pump>CPU>other heat sources>radiator>res. As long as you are getting the heat moved away, is all that matters though.
Greenman
22,296
6,463
I use a header on the pump outlet so each block has it's own water supply, and 3 inlets on my res.
racinjimy
73
your setup is exactly like mine
res> pump>rad>cpu>gpu>res
the water will reach steady state after a while so order doesn't really matter exept for having the res physically above and just before the pump............................
Mrvile
14,066
Also you guys with the D4's does the thing seem loud to you? I mean I was expecting quieter but this thing really whines.
