Well, I recieved this from my friend via email, so that sometimes kills the legitmacy of it. But I'm posting it here to see what you all think of it. If it all turns out to be true, perhaps more people will be drinking water soon 🙂. I already drink water and can vouch for some of the side affects when I switched from soda to water, but other than that I'm not sure of.
Here it is:
> This is really an eye opener.... Water or Coke?
> We all know that water is important but I've
> never seen it written down like this before.
> Water
> 1. 75% of Americans are chronically dehydrated.
> (Likely applies to half world population)
> 2. In 37% of Americans, the thirst mechanism is
> so weak that it is often mistaken for hunger.
> 3. Even MILD dehydration will slow down one's
> metabolism as much as 3%.
> 4. One glass of water will shut down midnight
> hunger pangs for almost 100% of the dieters
> studied in a U-Washington study.
> 5. Lack of water, the #1 trigger of daytime
> fatigue.
> 6. Preliminary research indicates that 8-10
> glasses of water a day could significantly
> ease back and joint pain for up to 80% of sufferers.
> 7. A mere 2% drop in body water can trigger fuzzy
> short-term memory, trouble with basic math, and
> difficulty focusing on the computer screen or on a
> printed page.
> 8. Drinking 5 glasses of water daily decreases
> the risk of colon cancer by 45%, plus it can slash the
> risk of breast cancer by 79%, and one is
> 50%less likely to develop bladder cancer.
> Are you drinking the amount of water you should
> every day?
> COKE
> 1. In many states (in the USA) the highway patrol
> carries two gallons of Coke in the truck to remove
> blood from the highway after a car accident.
> 2. You can put a T-bone steak in a bowl of coke
> and it will be gone in two days.
> 3. To clean a toilet: Pour a can of Coca-Cola
> into the toilet bowl and let the "real thing" sit for
> one hour, then flush clean. The citric acid in Coke
> removes stains from vitreous china.
> 4. To remove rust spots from chrome car bumpers:
> Rub the bumper with a rumpled-up piece of Reynolds
> Wrap aluminum foil dipped in Coca-Cola.
> 5. To clean corrosion from car battery terminals:
> Pour a can of Coca-Cola over the terminals to
> bubble away the corrosion.
> 6. To loosen a rusted bolt: Applying a cloth
> soaked in Coca-Cola to the rusted bolt for several
> minutes.
> 7. To bake a moist ham: Empty a can of Coca-Cola
> into the baking pan,wrap the ham in aluminum foil,
> and bake. Thirty minutes before the ham is finished,
> remove the foil, allowing the drippings to mix with
> the Coke for a sumptuous brown gravy.
> 8. To remove grease from clothes: Empty a can of
> coke into a load of greasy clothes, add detergent, and
> run through a regular cycle. The Coca-Cola will help
> loosen grease stains. It will also clean road haze from
> your windshield.
> For Your Info
> 1. The active ingredient in Coke is phosphoric
> acid. Its pH is 2.8. It will dissolve a nail in
> about 4 days. Phosphoric acid also leaches calcium
> from bones and is a major contributor to the
> rising increase in osteoporosis.
> 2. To carry Coca-Cola syrup (the concentrate) the
> commercial truck must use the Hazardous material
> place cards reserved for Highly corrosive materials.
> 3. The distributors of coke have been using it to
> clean the engines of their trucks for about 20
> years!
> Now the question is, would you like a glass of
> water or coke?
> *name info removed to protect the originator (although perhaps they would be happier if it was kept, not sure)*
Here it is:
> Water
> fatigue.
> printed page.
> every day?
> COKE
> minutes.
> your windshield.
> For Your Info
> years!
> water or coke?
