Wasted heat from combustion engines...
alkemyst
83,769
19
I dont really understand that. Is it based off of flip flop circuits and capicitors?
I am not sure the technologies, DoD uses them...they have reserve power and use the heat from the exhaust to power gps and surveillance.
Modelworks
16,240
7
There are designs , classified designs, that use heat to boil a liquid (ammonia) that creates pressure. the pressure then passes through a valve that mechanically modulates the stream into pulses that contact a piezoelectric device to generate power. The liquid cools and the cycle repeats.
greenhawk
2,007
Well, you don't have to use air - but other gases will work.
True, but then the reply was more directed at the nuclear powered air plane. Using non-air based fuel for thrust in those situations means the "never need to land" of the plane becomes problematic.
disappoint
10,132
382
From my minimal nuclear physics knowledge...
Uranium 238 is basically an exothermic decay process. The Alpha (hydrogen) and beta (electrons) expelling from the nucleus produce minimal "thrust."
Wow. Hydrogen and electrons expelling from a nucleus.
Were you expelled from physics class?
