Originally posted by: MrDudeMan
you probably werent a jerk, but why be so pushy and ask for four new quarts? thats kinda ridiculous. granted, 1.5 quarts too much wont help a whole lot, but putting in exactly what it calls for isnt the best idea either. the more you put in, the higher it stays in the lines, and the faster it gets to the block on a cold start. in a 4.5, 5 quarts would be what you really should pour in. when you exceed normal pressure, it breaks down the gaskets and o-rings in the block and will eventually cause a small leak. that takes a long time though...unless you put in a lot more than 1 extra quart.
I asked him to do that because he had already had it up on the lift twice, and it still wasn't right, I was tired of waiting.
I was a bit anal about it all because I've heard that having too much oil in the crankcase can cause it to turn into a whipped cream type substance.
I'm not a mechanic, but I wasn't about to take this guys word that it wouldn't hurt anything, "even if we did over fill it"
