Edited: Was hot at the time of posting.
Gateway FPD2185W 21" Widescreen High-Performance LCD Flat-Panel Display
www.gateway.com
search for FPD2185W
Widescreen High-Definition Resolution
With the 1680 x 1050 pixel display, you get 35% more pixels compared to a 1280 x 1024 display. Display two letter-sized documents side-by-side, expand a large spreadsheet or even watch a movie in widescreen format with the super size screen.
Picture-in-Picture Feature
Watch TV or a DVD while you work on a computer application with the picture-in-picture feature. Hit the Swap button and the main display image and the picture-in-picture video trade places.
Smooth Cinematic Quality
Get cinematic-quality images with the DCDi® by Faroudja with Advanced Video Smoothing Technology on composite and S-Video inputs. Moving images will appear clear and smooth, without rough pixilated edges.
Multimedia Display
This versatile screen can display just about anything. From notebook to TV to video gaming, the 21? Widescreen can accommodate almost any video content: PC, cable TV, satellite TV, video camera, DVD player, game consoles and VCR through its five video ports.
The Rotating Screen
Go from widescreen landscape view to portrait view with a flick of the wrist. With EZTuneTM Software and its auto-sensing display rotation, the image automatically rotates for you, making your 21? Widescreen a 21? "longscreen". View your favorite Web pages the way they were intended to be seen, without scrolling, or create graphic design in portrait-view. And, with an optional upgrade to a 3-year limited warranty, your LCD display will be going strong for years to come.*
Amazing Flexibility
Comfortably view your display with the height-adjustable tilt-swivel stand. The ergonomic design lets you adjust the display to accommodate your position. Whether used at home or at work, let us do the pivoting for you.
Ready for Tomorrow
The 21? Widescreen comes with built-in innovative compatibility features so you can handle tomorrow?s technology today. The HDCP Video Content Encryption Chip allows encrypted high-definition video to be played on the display through the DVI port. The Protection Video Path ensures the display is compatible with future software packages.
Extensive Display Control
Included with every 21? Widescreen is our EZTuneTM software. Get the precise visual quality you want by controlling many of the display settings from your computer. The user-friendly dashboard gives you extensive display control so you can make the adjustments on the usual settings such as brightness, contrast and balance, and the not-so-usual, such as color temperature and gamma settings.
Easy Connectivity
Built-in powered four-port USB hub (2.0) comes standard. Connect your keyboard and mouse in 2 USB ports; you?ve got two more for any thumb drives or other USB devices you wish to connect.
* Limited warranties and service agreements apply; visit gateway.com, or call 1-800-846-2000 for a free copy. Service agreements are issued and performed by third parties. May not be available in all locations. Accidental Damage Protection not available in all states. Phone charges may apply for tech support. If purchased, on-site service technician will be sent if necessary, following phone-based troubleshooting. Availability varies. Other conditions apply.
Specifications
Aspect Ratio 16:10
Brightness 300 cd/m2
Colors 16.7 million
Connections and Inputs ? Analog (VGA): 15-pin mini d-sub VGA
? Digital (DVI-D): 24-pin DVD-D (supports 480i, 480p, 720p and 1080i). Includes HDCP (High-bandwidth Digital Content Protection)
? Composite video
? S-Video
? Component Y Pb Pr (supports 480i, 480p, 720p and 1080i)
? AC power input
? USB 2.0 B-type (PC input)
? USB 2.0 A-type (PC input)
Contrast Ratio 1000:1
Dimensions (WxHxD) 19.45" x 15.35" x 8.2"
Frequency Horizontal: 31-81 KHzVertical: 56-76 Hz
Lamp Type/Life 50,000 hours
Model Number FPD2185W
OSD Languages English, French, Spanish, Italian, Japanese
Panel Size 21-inch diagonal
Panel Type 21-inch viewable
TFT active matrix
S-PVA
Anti-glare coating
Pixel Pitch 0.0106 x 0.0106 inches (0.270 mm x 0.270 mm)
Pixel Resolution 1680 x 1050 (native) (75 Hz)
Response Time 8 ms (gray to gray)
Viewing Angles 178° horizontal, 178° vertical
Weight 18.74 lbs. (includes height-adjustable stand)
www.gateway.com
search for FPD2185W
Multimedia Display
The Rotating Screen
Amazing Flexibility
Ready for Tomorrow
Easy Connectivity
Specifications
Aspect Ratio 16:10
Colors 16.7 million
? Composite video
? S-Video
? AC power input
TFT active matrix
S-PVA
Anti-glare coating
