I did read that SATA3 are a little different, any truth to that?
SATA Revision 2.0 (SATA 3 Gbit/s)
All SATA data cables meeting the SATA spec are rated for 3.0 Gbit/s and will handle current mechanical drives without any loss of sustained and burst data transfer performance.
9: Does SATA 6Gb/s require different connectors and cables to support the higher transfer speed?
A9: The same cables and connectors used for current SATA 1.5 and SATA 3.0 Gb/s implementations can be used to connect SATA 6Gb/s devices, although SATA-IO recommends quality components be selected to ensure data integrity and robust operation at the faster SATA 6Gb/s transfer rate. Keeping the existing SATA connector form factor enables SATA 6Gb/s to be designed into the same cost-conscious hardware architectures while minimizing infrastructure changes.
Q14: Were there any attenuation or jitter issues that had to be addressed with the jump to 6Gb/s?
A14: Ensuring signal integrity was the primary challenge in doubling the SATA transfer speed for a second time while using the same cables and connectors that were originally defined for the first generation 1.5Gb/s version.
I read that FAQ from SATA-IO to mean that existing SATA cables will function at 6Gb/s speeds but that the "lower-quality" ones out there (the questionable ones to begin with) are probably not going to give you full-speed bandwidth as the error-correction protocol overhead will eat into the effective bandwidth.
But clearly they intend for SATA 6Gb/s to be capable on existing first-gen cables:
from what i've seen sata 3 have that metal clip on them as well
Yellow are the best by far.
I've thrown away roughly half of my old USB cables, because they cause problems with fast USB 2 products (like hard drives and optical drives).There is no such thing as SATAI or SATAII cables, only ones that work right, and ones that don't. Like others have said, it's like USB 1.0 and 2.0, the cables are the same, it's just marketing to get you to buy new cables.
My mind is blown, I can't believe the OP made an erroneous discovery. He's like an anti-scientist.
All works fine,
anyone else unimpressed with SATA cables in general?
seems like they all suck
No it doesn't. In every screenshot you do have different values, yet you don't claim that you have changed anything. Therefore, you seem to re-run the benchmark and to get different values every time. That sounds more like random, than repeatable measurement. And random smells like trouble in this context. 😛All works fine,
Aero is eye candy, designed to impress teens the eldery and your aunt rose.
Hardcore users run Windows stripped down to bare bones for performance.
Time for tweakboy to run some more benchmarks. ^_^Actually Windows runs a lot slower if you turn off aero.
How can you guys dispute such science?!
He has charts and graphs.
CHARTS AND GRAPHS!!
He may be confused about the cable classification, but I don't see why so people people are willing to dismiss his experience right off the bat.
lmao yea those link depot cables are cheap as shit and they work just fine. i have a stack of them sitting in my spare's bin cause i get them for like 2 bucks and i replace crapped out SATA cables for people all the time (you'd be surprised how often they wear out)Hey wat up razel, the cable was in perfect condition and I tried plugging and replugging it few times it was nice connection and I used a strong light soo I didnt do anything stupid. Nicely connected and that Crystal mark before and after. Well the before I was using it on that SATA I cable for almost a month. Soo I know if I plug it in again I will get same results.
ALSO FYI,, I tried 2 different SATA cables at first. I knew something was wrong with my Crystal Mark.. Soo I went to Fry's got 'specifically SATA II uv blue cable for 4.99 and plugged her in and went to safe mode ran that Crystal Mark.
Vista is a dead OS, let's focus on 7.I'll post a video when I get home from work. Turning Aero off makes Vista/7 slow to the point of being virtually unusable.
