War Bears
Originally posted by: Salvatore
Figures...I got the keyboard all green once, without trying...now I realize I need it and I try and it's still red. Damnit.
If you can get it to all red (easier than all green), click all four corners in order (like going clockwise) and then click the center..
How do you know that?
I think there's a noticeable pattern to these things, but BSG is on in a minute, literally. I really liked this thing too. BTW I couldn't get it all red again either. I fail.
How did you guys get past the par twhen the guy is in the room inside?
have the guy on top kill the 2 guys. then you can messs with a box. hack the box then the guy in the bathroom can hack into the system.
i had the water flowing and tried the door and it opened.
Fill the room with water (run the water like two or three time), then when its around your next, try opening the door, the chair should fall, try again and violay.
hint have the dude by the van toss a grenade, then jump on the van to get away from it. Then try the bathroom door again.
you dont have to do that. just turn on the elevators then try the door.
i have had the shooter kill the 2. had the one fall out the window but now im stuck. only 2 baddies to kill!
That's where I'm at as well.
not anything you can do.
i get to the3rd floor (marked 2nd by the stair). and i can use th eelevator but it wont let me since there is a enemie upstairs. there is 1 more enemy on 3rd floor but nothing i can do.
the other 3 guys are useless at this point.
IM STUCK!
IM STUCK!
Have the guy on the roof slice the tower. Have the guy outside throw a grenade, get up on the vehicle, and then jump.
IM STUCK!
yeah but you kill a hostage.
edit nevermind. i guess it changes at this point
IM STUCK!
Plus the guy outside dies when he lands.
IM STUCK!
He doesn't die if you slice the tower causing the ball to knock over the bank sign, which he'll land on. You just need to make sure the ventilation system is off first.
Are you supposed to make the guy on the outside commit suicide with the grenade to shut the bathroom window? That's the only way I could get the door open.
(that is, throw a grenade, then jump on the truck and try to jump off... he'll time the jump so the grenade propels him up and when he comes back down he shuts the window and floods the bathroom the rest of the way (and dies)
No, just throw the grenade, get out of the way and let it go off. You should then be able to open the door.
