- Mar 6, 2001
- 59
- 0
- 0
Hello...I just had a computer built by a local integrator. I specified an AMD XP1700+ CPU with an ABIT KG7 mobo and 256 MB PC 2100 DDR RAM.
While I wont say I distrust the integrator, I will say that I did not see them install the CPU or the DDR RAM.
The OS is WIN XP HOME and Norton Utilities 2002 is installed on the system.
How can I verify that I actually received an AMD XP1700+ CPU and 256 MB PC 2100 DDR RAM? (without opening the case and looikng inside and removing the hsf etc?)
Thank you.
Thank you.
