One option is to use an inverter-charger and deep cycle batteries for golf cart or RV. You can add as many as you want to increase capacity. This is the one I have:
tripplite.eaton.com
If you do it to a regular UPS just make sure to add a fan but one issue is the components may not be rated for continuous duty so it may still end up being less reliable. I have tried it though. I added 2 80ah batteries in series (24v UPS) and it ran off them for a long time.
Oh and to answer your question on inverter grounding. Ideally, you want it to not actually go anywhere, that way you can connect it to ground yourself. But a lot of inverters do this weird thing where the ground is 60v potential between the two output slots. This is not ideal because in a proper setup the neutral and ground should be tied together but you can't do that with those inverters. Best bet is to take a multimeter and test voltage between ground and both slots to see what you get.
With the inverter turned OFF and make sure you drain the capacitors, you can also do continuity (or ohm) test to see what you get.
Eaton - APS750 | Eaton
