Wacom Graphire3 4x5" Tablet, Sapphire = $49.99, Gray = $79.99 after MIR
Dug
3,469
Originally posted by: Winchester
The only thing that royally sucks with this is if you have a dual monitor setup. It is out of proportion unless you disable the 2nd monitor. The height is correct, but the width is not since it pans both monitors. I was trying to trace one of my drawings and took me a while to figure this out. I was about to break the pad I was so pissed. Anyway, just thought I would post in case someone else has the same problem.
Wish they had a solution to this problem.
You don't have to disable the monitor. Just go into the tablet properties and map the tablet to one screen. It allows you to pick which one to use or you can set it to use a portion of the other monitor.
For easier tracing- scan in the picture and trace it using a layer in Photoshop. That way you can zoom in and you will never loose your place and have a lot more control.
neutralizer
11,552
Why are there diff prices for diff colors? Sounds like a good deal tho. I might pick it up for some home photoshopping.
ActuaryTm
6,858
12
Originally posted by: Sonarcade
sapphire = $79.99 as well
maybe I'm missing something here. Too bad about the rebates
You may want to reread the entire thread a bit more closely; the original post was made December 21st, 2003. KydLynx was kind enough to search for the prior thread, and simply post an update.
Any color Graphire3 available from CircuitCity is now $79.99 after the $20 rebate posted.
Sonarcade
139
There's no indication that the deal has changed throughout the whole thread. There's just a "Deal is back" comment, which when read, I assume that the deal has remained intact. I guess flames don't have to have all caps or !s after all...because that's what the "reread the entire thread a bit more closely" comment was, of course.
gwlam12
6,946
come on, didn't sound like a flame to me at all. of course he couldve just said the deal changed, but yea, dont take it so personal. :)
