w key not working with other keys
toughwimp11
415
So recently, I've discovered that my keyboard no longer allows w to work at the same time as other keys. this isnt problematic if i'm typing or something but it is annoying in games because it means i cant go diagonally since w+a or w+d doesnt work. i have a microsoft comfort curve 2000 keyboard. I havent always had this problem and i dont know what brought it on. any suggestions?
edit: i'm not sure if there are other keys that dont work simultaneously since i only noticed w because of shooters.
modoheo
187
How about WMD?:)
I clicked on this thinking it was going to be some kind of political analogy.
I guess you did say you "only noticed w because of shooters." After reading that, I went back and re-read to make sure I wasn't being dense.
Oh well. Keyboards are cheap. Not sure what else to tell you.
toughwimp11
415
heh, i'm not quite sure how you saw this as a kind of political analogy but...
problem solved!!! i just took apart my keyboard, cleaned it with some alcohol and tada, it works. sorry about the post, i thought it was computer related since the w key still worked, it just didnt work in combination with other keys.
TheKub
1,756
Originally posted by: Chiropteran
You should take apart your keyboard and try cleaning it with some alcohol.
Beer would probably be a bad idea, but anything 160 proof or higher should work! ;)
