Ok, so my monitor arrived this morning, plugged it all in, and if I use the DVI cable, it says "No Signal". If I use an adaptor and the VGA cablle, I get display, so Im trying to work out what this could be.
I know there are a few types of DVI, the video card out (for those who dont know) is the one with ALL pins, and the cable from the monitor has 2 sets of pins, and on the side, only the wide one (will find some pics to show you if you need more explanation)
So, do you think that because the cable doesnt have all the pins, its not working, or is it a busted cable, or busted input on the monitor?
EDIT: ok, heres a link http://www.datapro.net/techinfo/dvi_info.html#Page06 My vid card has DVI-I Dual link out and the cable is DVI-D singe link. any reason this wouldnt work?
