VPN help
RBBRMADE
491
I have two linksys VPN routers.
I need the basics of setting up a VPN between the two.
How do I access one from the other once I am set up?
Thanx,
Ron
JackMDS
29,563
432
As far as VPN concern there is two kind of Entry Level Router.
1. VPN Through.
Which mean that the Router is ?Kind? to VPN and let it through, but doe not participate in the actual VPN generation.
2. VPN End Point.
The Router actually can process VPN in its Hardware.
If it is No. 2 then you got yourself a Nice deal.
Link to: VPN Setup for Routers - Getting it to work with an IPSec Client.
The following is mainly a collection of Entry Level software issues.
Link to: Introduction to VPN.
Link to: Use Virtual Private Networks for Secure Internet Data Transfer.
Link to: Configure Windows XP Professional to be a VPN server.
:sun:
RBBRMADE
491
Both routers are VPN endpoint.
Linsys BEFSX41
Linksys RV016 (although I am using a WRV54G right now to figure this out).
Thanx for the info!
Ron
RBBRMADE
491
Originally posted by: JackMDS
2. VPN End Point.
So, after I set up the routers, then what?
I am told that since we are running terminal services, the tunnel will provide all we need, and the VPN will work without any other software.
Does this sound right?
Do I need to forward any ports, etc...?
Thanx again,
Ron
RBBRMADE
491
Having some problems, here is my log:
2004-08-03 01:10:18 IKE[1] Rx << MM_I3 : 69.132.141.88 ID, HASH
2004-08-03 01:10:18 IKE[1] Tx >> MM_R3 : 69.132.141.88 ID, HASH
2004-08-03 01:10:18 IKE[1] Rx << QM_I1 : 69.132.141.88 HASH, SA, NONCE, KE, ID, ID
2004-08-03 01:10:18 IKE[1] **Check your Local/Remote Secure Group settings !
2004-08-03 01:10:18 IKE[1] Tx >> Notify : INVALID-ID-INFORMATION
2004-08-03 01:12:53 IKE[1] ERROR: This tunnel should not be initiator !
2004-08-03 01:18:56 IKE[6] Rx << MM_I1 : 69.132.141.88 SA
2004-08-03 01:18:56 IKE[6] Tx >> MM_R1 : 69.132.141.88 SA
2004-08-03 01:18:56 IKE[6] ISAKMP SA CKI=[eeff78c4 b60d730b] CKR=[3fcc60e4 e1c3f084]
2004-08-03 01:18:56 IKE[6] ISAKMP SA 3DES / MD5 / PreShared / MODP_1024 / 28800 sec (*28800 sec)
2004-08-03 01:18:57 IKE[6] Rx << MM_I2 : 69.132.141.88 KE, NONCE
2004-08-03 01:18:57 IKE[6] Tx >> MM_R2 : 69.132.141.88 KE, NONCE
2004-08-03 01:18:58 This connection request matches tunnel 1 setting !
2004-08-03 01:18:58 IKE[1] Rx << MM_I3 : 69.132.141.88 ID, HASH
2004-08-03 01:18:58 IKE[1] Tx >> MM_R3 : 69.132.141.88 ID, HASH
2004-08-03 01:18:58 IKE[1] Rx << QM_I1 : 69.132.141.88 HASH, SA, NONCE, KE, ID, ID
2004-08-03 01:18:58 IKE[1] **Check your Local/Remote Secure Group settings !
2004-08-03 01:18:58 IKE[1] Tx >> Notify : INVALID-ID-INFORMATION
2004-08-03 01:19:16 IKE[1] ERROR: This tunnel should not be initiator !
2004-08-03 01:20:08 IKE[1] Rx << QM_I1 : 69.132.141.88 HASH, SA, NONCE, KE, ID, ID
2004-08-03 01:20:08 IKE[1] **Check your Local/Remote Secure Group settings !
2004-08-03 01:20:08 IKE[1] Tx >> Notify : INVALID-ID-INFORMATION
