woolfe9999
- Mar 28, 2005
- 7,153
- 0
- 0
I don't think voting is useless. Both major parties are more alike than not, true; in our system of government they have to be. But there are still differences, some of which are surely important to the vast majority of people. If none of the differences are important to you, then at least you can select which candidate you think would do a better job. If the two parties' similarities are anathema to you, you can at least vote for a third party, which if nothing else moves the polity a bit in that direction.
I don't think I disagree with you here, but I want to add something. The political parties are actually quite different. Often the result of electing one POTUS or congressman/senator of one party versus another makes little difference in resulting national policy because that policy is determined through a process of compromise in a system where each party has enough presence to check the power of the other. If that was not so, I suspect we'd see a radical difference in policy. Which is to say that if one voting bloc or another suddenly decided that voting was worthless, we'd probably see quite a lurch in one political direction in our actual governance.
