Voltage switch on power supply: 115 or 230? Which one should I use?
WDCentral
188
I have a little red switch on the back of my power supply for 115 and 230. What does this do and which should I have it set on? I should note I have been having some reset problems (the system does not boot and I must cycle power). I dunno if it could have anything to do with this...
Thanks for your help,
Ben
TwoFace
1,811
Heh, someone are having fun huh?
WDCentral, according to your profile you live in the US, if I remember correctly you've got 115V from the outlet there, so that's what you should use ...
Two-Face
