Vista Problems
MBrown
5,726
35
For some reason whenever I try and take my PC out of hibernation mode it locks up. The screen stays black and I have to restart. My rig is in my sig. Any suggestions?
Edit: Actually I cannot edit my system rig in my sig so I will just till you guys.
4400X2 @ 2.4
2GB of DDR
8800gts 640MB
22" LG widescreen LCD
160GB hard drive
480W NeoPower Power supply
Memorex DVD burner
Windows Vista Home Premium (obviously)
Edit: I just had a BSOD and I got this error message
xxx stop: 0x0000000A (0x101DC424, 0x00000FF, 0x00000000, 0x818f1C9C)
What is this?
zig3695
1,240
sounds like an xp problem to be honest. i havent had any such issues with sleep or hibernate in vista. havent heard much problems either. i guess you first check your monitor and video card drivers, then make sure your mainboard bios is up to date as well as the power settings in the bios are set right. wish i could help more, these kind of problems are usually easily fixed or never fixed at all....
pcnerd37
944
I had a similar problem in that the hard drive would shut off after so long as a power saving feature. I just disabled it so I dont have that issue anymore.
MBrown
5,726
35
bump for another question. I got a BSOD and got this error
What is this?
