visioneer 5300 USB scanner problems
Slapus
i'm running win xp pro and trying to get this "Onetouch" Visioneer 5300 USB scanner to work. Win XP recognizes the scanner in the device manager but it says there are no drivers installed, even though i've installed the drivers i got off visioneer's website a couple of times. also the scanner's software displays a little icon in my system tray that should "ready" the scanner but whenever i boot up it says "Trying to connect scanner" then "Connection failed." i've tried everything i could think of. anyone have any suggestions or ideas?
thanks in advance
boomerang
18,883
641
Maybe I'm overlooking something, but it doesn't appear that your scanner will have support for XP. They state that the driver they have is for 98/ME/2000 only. :(
boomerang
18,883
641
Contact their tech support through email. I have before, and they answer back usually the next day.
