Virtual PC 2007 vs VirtualBox vs VMWare Server/Workstation
i think one of the biggest selling points of workstation is it's ability to take on the fly snapshots.
great for development work, or for server administration - make a change and if it breaks something, just revert back to the snapshot.
server/esx (bare-metal) is more for production systems, integration with VMi (which is not free). you can get away with running it on a desktop as well.
you can take snapshots as well, but it's not as robust as Workstation's ss manager.
I mainly want to use either for older and newer windows OS's and also use it with non windows os's. I currently have been using vpc 2007 sp1 but that is very limiting. Besides the snapshot thing is there anything else that one does better then the other?
Server does that too, the only difference is that Workstation can take mulitple snapshots while you only get 1 per VM with Server.
Oh so the hardware virtualization and all that would be the same on server as in workstation?
There's other things too like drag and drop between the host and guest IIRC, But I never use them. Take a look at the VMware product page. I essentially do an install to a VM then forget about it being a VM, I IP it and treat it like another machine on the network.
There is an overwhelming amount of options that far surpasses vpc in alot of ways. I take it in your opinion vmware is better?
Go ahead and try virtualbox. Its easy to use and will do everything you need it to do just fine. I ditched vmware products for it because server is user-unfriendly overkill, player is crippled and workstation costs money (only ever used it during the trial period and liked it, but...).
You got nothing to lose by trying for yourself.
I use vpc at home with Windows 2000. I use it as a work machine to remote into my work stuff because I did not want to install cisco vpn on vista. I use vmware at work, its great for a lot fo stuff, but for people just getting started, vpn or virtualbox then upgrade to vmware.
