and once again I am correct. lol :sneaky:Since everybody is curious about my PSU, here it is:
Bestec Model: ATX0350D5WA
Input: 100-127V-10A 200-240V-5A 50/60Hz
Output: 350W Max
+5V = 18A
+3.3V = 17A
+12VA = 12A, -12V = 0.8A
+12VB = 18A, +5Vaux = 2A
+3.3V & +5V 160W MAX
+12VA & +12VB 300W MAX
just get a 5770 and you will be set.
ZOMG Bestec? Please burn that thing in a fire ASAP before it takes your PC with it. When I ran my PC shop I had a bin of burnt PSUs that I kept in the back room, and easily 4/5ths of them were Bestecs, mostly out of HPs and Emachines. In my experience a failed PSU doesn't normally take the mobo with it, but with the Bestecs it was a majority of the time.
Lots of hot deals on decent 500w PSUs come through for under $40, Antec, Corsair, etc.
they are junk comapred to most power supplies but for a fairly basic pc that wont push it to the limits it will be fine.ZOMG Bestec? Please burn that thing in a fire ASAP before it takes your PC with it. When I ran my PC shop I had a bin of burnt PSUs that I kept in the back room, and easily 4/5ths of them were Bestecs, mostly out of HPs and Emachines. In my experience a failed PSU doesn't normally take the mobo with it, but with the Bestecs it was a majority of the time.
well you can look and see but the last one I saw did.Thanks toyota...like I said before, you're psychic.
I'll probably get the 5770. You wouldn't happen to know if my PSU has a 6 pin for the 5770 as well do you? Not familiar with it 😉
This must be recent, because actually Dells used to have quite well-built and seriously under-rated (i.e. much better than spec) PSUs made by Delta. Dunno when they went crappy cheap like HP.Yeah it is a dell machine afterall...you don't expect them to have a Cosair in there do you?
about 2-3 years ago they started getting cheap with the power supplies. I believe they are just like HP/Compaq and Gateway in that their power supplies can now be Delta, Bestec or Hi Pro.This must be recent, because actually Dells used to have quite well-built and seriously under-rated (i.e. much better than spec) PSUs made by Delta. Dunno when they went crappy cheap like HP.
I wouldn't risk a 108W TDP 5770 on that. 5750 (86W) maybe.
I already linked to a review that showed even under full load with an i7, a system with the 5770 only pulled 256 watts at the wall. again factor in efficiency and his Q8300 and you are looking at probably below 200 actual watts. his psu provides 300 watts on the 12v alone. even if that psu is a bit cheap and doesn't quite make that in reality, he should still be fine.This must be recent, because actually Dells used to have quite well-built and seriously under-rated (i.e. much better than spec) PSUs made by Delta. Dunno when they went crappy cheap like HP.
