After having my Wii hooked up to a different TV for a few months I decided to hook it up to my TV on the top floor with surround sound and what not.
This afternoon when I hooked up the Wii I got no video only sound from the Wii.
After following some directions I found online of how to fix this, unplug the Wii from the receiver and plug directly into tv then plug back into receiver, this fixed the issue.
Fastfoward to later this evening and I have the same problem again, but this time no matter what I changed out it refuses to give me video only audio again.
I have a Yamaha V463 receiver with an HDMI cable to the TV for video, a Fiber Optic cable to the tv for sound since the receiver does not do audio over HDMI, I also have a single video cable running from the back of the receiver in the monitor out port to the back of the tv to the video in.
I tried known working cables for the following with no positive results:
Different HDMI cable, different Video cable.
The Wii has video output when connected directly to the tv.
I am thinking either the receiver is starting to go out or the power issues in the room are getting worse due to to much load. There is only a 15 amp breaker powering the entire room, this is a rental so nothing I am willing to do about it.
Is there anyway to test the ports on the receiver or maybe a way to put a mutlimeter on the receiver and see what kind of voltage it is outputting.
Where would I put the meter at for this?
Thanks in advance.
Thanks in advance.
