mvbighead
Anything can be fixed, but it might not be worth it. With over 100k on the clock and close to 10 years, a minor vibration might be caused by 10 things that are slightly worn, sway bar bushings, control arm bushings, tie rods, ball joints, struts, wheel bearings, tires, CV joints, drive shafts, alignment... Every part on the car is going to show some wear that may or may not be causing the problem. It's difficult to guess which part specifically is the culprit when everything has some minor wear, you end up replacing things one part at a time and the problem never goes away or you end up replacing everything at once and it cost more than the car is worth. My suggestion was to look at the things that are easy to diagnose and repair, if it's not one of those things I'd just accept that I drive a 10 year old car with 100k miles and live with the vibration.
In my area, an 02 Maxima with 130k seems to go for about 8000. A 10 year old Maxima with 130k miles is not a piece of crap that someone would expect to vibrate going 60 mph.
And, if my 00 JGC with 149k doesn't vibrate when cruising down the interstate/hwy, there is no reason for a car that is 3 years newer to do it with 22k less miles.
In any case, you'd be the first person I have ever heard suggest that a vibration is something that one should live with in any car. Whether it's a 300-400 brake/rotor job, or a rebalance, or new tires, it's something that is most likely easily corrected and will make the car more pleasant to be in.
