I recently moved my computer to another room. After I did this, the picture sort of started vibrating. Or shaking or wiggling. I don't really know how to describe it. This only happens when the refresh rate is less then 100Hz. My monitor only does 100Hz at 1024 x 768, which is really low. I usually like to keep mine at 1600 x 1200, but it only does 70Hz at that resolution.
It seems to be consintrated at the sides, and is most visible with light colors.
Is this interfierance of some sort, bad electricity, or something obvious that I havn't thought of?
BTW - My monitor is a Komodo K95
Thanks!
Thanks!
