VERY HOT DEAL ON FX 5200
tigerdirect < * and I don't recommend ordering from them. With that out of the way...
The 5200 isn't as bad as most people think. Doom3 on normal settings is not playable IMO, but it does run the full ARB2 path with all effects playable if you lower the resolution down to 512x384. 😉 Many games play pretty well at 1024x768 and the more demanding ones are playable at lower resolutions.
I ran a bunch of benchmarks on my PCI 5200 here. The AGP version is 0%-20% faster, depending on the benchmark (most games are 10-20% faster on the AGP version).
My card has default clock speeds of 250MHz core and 500MHz memory (128-bit). Some highlights @ stock speed:
Doom3 512x384LQ, ARB2 path, all effects enabled demo1 28fps (not in the link above)
Q3A 1600x1200HQ max demo four 61.7fps
RTCW 1024x768HQ max checkpoint demo 57.0fps
3DMark03 1024x768x32 1590
Far Cry 800x600 autodetect quality (medium) regulator demo 34fps
CS:S VST all options high, reflect world, trilinear, no AA 800x600 54fps
Tomb Raider 800x600 PS1.4 paris3 demo 39fps
UT2003 botmatch 1024x768 antalus + asbestos demos avg 58fps
and lowlights:
Doom3 640x480LQ, ARB2 path, all effects enabled demo1 20fps, not playable
Halo ~22fps even in PS1.1 mode, not playable
Aquamark 3 9137 (GFX 1014)
And as I mentioned above, this was from the PCI version... the AGP version would generally do a lot better.
There are 64-bit 5200s and those are dog slow, but most of the regular 5200s with 128-bit memory are fine for light gaming. Halo and HL2 are probably the only 2 games that are completely unplayable at stock speeds. And I'm not sure about HL2, it may be playable at 800x600 with the DX8.1 path like CS:S is.
Originally posted by: Sentrion
I have an FX5200 (PNY) and it plays Doom 3 just fine. It certainly isn't the greatest card in the world, but it's one of the best for such a low price.
Your definition of "fine" must be a lot lower than mine. In these benchmarks the fx5500 (which is essentially a higher clocked fx5200) had to have settings turned down to 640x480, med quality just to get a whopping 29 fps. Maybe you are ok with 29 fps in d3, but I am not. I don't even like it dipping down to 40fps.
You should run time demo and then report back with your findings :evil:
Looks like a nice card if you just need one for normal use. Passive heatsink means no noise!
Too bad about the rebates. I'd pick one up if they didn't have such a bad rep. 🙁
why anyone would want to run such a visually stunning game such as doom3 in 640x480 resolution is beyond me.
Anyways that link in the OP is Canada. I noticed mainly due to the $251 shipping charges.
The card is $20 at the tigerdirect.com website, but shipping is about $10 for me. $30 for a FX 5200 is still an ok deal, but again the rebates.
Originally posted by: beaver
CompUSA BF has it $30AR with DVI port. It's better than TD's deal.
The mad dog one? The newer mad dog AGP cards only have 64-bit memory on them. bleh. The PCI version with the big yellow PCI on the front still have 128-bit memory interfaces.
Originally posted by: Munny
OKAY OKAY
so maybe that wasnt a very hot deal
wat about this one
XFX GeForce FX 5700 LE / 128MB DDR / AGP 8X / VGA / DVI / TV Out / Video Card
http://www.tigerdirect.com/app...8270&amp;Sku=P450-8515
You can get a much better 5700 non-LE for the same price (after shipping) elsewhere with no rebates: http://www.futurepowerpc.com/s...SA5700128&amp;REFID=PW
The futurepowerpc card has a much faster core speed (425MHz vs 250MHz @ TD) and faster memory. And most importantly it's not from TD. 😉
