Originally posted by: MCrusty
What ya need? Im on lvl 7
Originally posted by: Ionizer86
How do you put the head from the box in the contraption with 3 tiles?
Originally posted by: bockchow
made it too the rooms with a motercycle and one with a fire hose. still looking around though, got a screwdriver and put batteries in the flashligt and found some tiles under the carpet. also a grate under the door mat. freeking wierd
You have to set a mouse trap. And capture him!
Originally posted by: Mwilding
I am in space and have to use the PC to unlock the door. I entered the password and now see a picture of the first room...![]()
Im trying to figure out the high voltage/blown fuse thingy...
Reset the computer, the button on the far right.
lol did that.... OK listen this is what u do, the computer ONLY lets u go in those 2 rooms, you have to make a word out of the 4 letters in the 2 rooms..... YEAH type that then hit the enter key on the keyboard and it will unlock the door in your room to the right.
So easy yet so hard.
Josh
Josh
huh?
Josh
huh?
Ok when you are on the computer on that level, look in the first room, there are 2 letters on the wall. Click on the door and exit that room on the computer... There are two more letters in the room on the wall. The four letters are Y...E....A....H Type those four letters on the computers keyboard and click the enter key.
This will unlock the door in the acutal room you are in and you exit it that way.
NVM I just found out the letters are random, you may only have 3, I have seen Yeah, and Get so far..... Try to find the letters in those 2 rooms and make a word out of it.
Josh
Josh
huh?
Josh
I dont see any letters on any walls...which rooms?
