- Feb 12, 2004
- 1,288
- 0
- 0
Well I'm running the system in my sig, and I would have to say I'm very disappointed. I can't even get to 3.6 ghz stable at 1.65-1.7 volts. This is what I tried:
- 5/4 divider
- lax timings (which shouldn't be neccesary when running below default ram speeds neways right?)
- vdimm bumped to 2.6 and 2.7 (also not sure if neccesary...but i tired it)
- vcore from 1.65 to 1.7
- hyperthreading off (did nothing)
- pci/agp locked
I can't think of whatever else I tried, but absolutely nothing worked. I could boot into Windows at 3.6 but it would hard freeze on me within 15 minutes. I then rebooted and set everything to default, and within 5 minutes it froze on me again.
I'm starting to wonder if this board just doesn't overclock very well. I've tried 2 different chips without much success. I noticed a tiny bit of fluctuation on my vcore though. Could this be the Albatron's fault or more likely my psu? The only reason I ruled out my psu was because I never once had a problem in my previous setup.
I'm considering just ditching this board in favor of a nicer 865 or possibly an 875. Do you guys think this is a good idea? What models you you recommend? Should I also try another power supply while I'm at it?
- 5/4 divider
- pci/agp locked
