Hi,
A while ago I posted about this problem but now it is happening more frequently. I've had my rig for 2.5 months and what is happening now is that when I turn on my computer there are vertical white lines on the screen and once my computer gets into windows it seems that the display doesn't even refresh because if i move the mouse, etc. nothing changes.
Some suggested it might be my video card overheating but I have been monitoring it and the temperature never goes above 45 degrees. Also, the fan still works as I have checked it. I took the video card out and inspected it but don't see any damage as far as I can tell. What should I be looking for?
Any way to diagnose this other than trying to return the card? I'm not sure if I can RMA the video card 2.5 months after buying it so I'll have to look into it.
Thanks.
Thanks.
