Verizon wireless broadband
archcommus
8,115
How do plans like this work? Could it provide internet access to my desktop with the right equipment? And if I paid for such a plan, wouldn't it essentially be a regular cell phone plan at the same time?
mzkhadir
9,509
I think it would work with your laptop card that you have registered with them. It wouldn't work with anything else except bluetooth enabled phones that could use the service
From the FAQ
Devices
If I am currently a Verizon Wireless customer, do I need a new mobile number for the PC cards or can I use my existing number?
If you choose to keep your existing handset for voice calls, you will need to add an additional mobile number to your account for the PC cards. The PC cards have their own mobile number and ESN/MEID (Electronic Serial Number/Mobile Equipment Identifier) just like a wireless phone. Some PC cards are not voice capable, such as the PC 3220, the PC 5220, and the Sierra Wireless Aircard 555D.
Back to top
How do PC Cards work? PC Cards allow you to establish a connection to the Internet using a laptop computer when you are within the Verizon Wireless National Enhanced Services Area. The PC air card has an antenna and will pick up a wireless radio signal from the air much like your voice cellular phone. Back to top
Will the PC Cards work with my laptop? Verizon Wireless PC Cards are designed to work in any PC laptop computer running Windows 98SE, Windows XP or Windows 2000 that is also equipped with a PC Card slot (PCMCIA Type 2). Verizon Wireless provides software with each card, which is installed on the computer and will control all the functions of the card (activation, connecting/disconnecting, etc). Back to top
My PC Card won?t connect. What should I do?
There are several things you can try, in order:
Try rebooting the computer.
Make sure card is seated properly in the PC Card slot.
If you purchased your PC Card through Telesales, you may still need to accept the terms of service.
Call the automated line at 877-807-4646 with your 12-digit order number, the PC Card wireless phone number, and the last 4 digits of your Social Security Number.
Uninstall the software through Control Panel > Add/Remove Programs then reinstall the software.
Verify the computer has the latest Operating System updates and hotfixes
Note: Hotfixes are available on the Microsoft website.
Try running Activation again through the VZAccess Manager Options menu. Go to Options > Activation...
Try running the Setup Wizard again through VZAccess Manager Options menu. Go to Options > Run Wizard...
If none of these options works, you?ll need to call Data Technical Support at 866-788-9387.
Back to top
Can I get an external antenna to improve my signal?
All of the Verizon Wireless PC Cards come with either a removable antenna or an extra connection port for an external antenna. This can be used when you are inside a building or a car to help pull in a stronger signal and improve your connection in fringe or low reception areas. Verizon Wireless provides two types of external antennas:
Magnet Mount can be placed on the roof of a car
Window Mount is mounted on the edge of a car window or attached to the window in a building. An adaptor cable will be required to connect the external antenna.
The external antennas and adaptor can be purchased on the accessories section of www.verizonwireless.com.
Back to top
tw1164
3,995
I don't think you have any voice capablities, only data...I guess you could do VOIP
PlatinumGold
23,168
ya, i have an EVDO account. currently using an Audiovox 6600. so it's like a blackberry account where i pay $49.00 / month for evdo bandwidth (600 to 800 kb/ sec).
cool think is, i can use my Audiovox 6600 as a modem to my laptop so that i can get evdo bandwidth anywhere in the northeast (pretty much).
it's pretty sweet.
archcommus
8,115
Wouldn't I be able to purchase an external USB device to pick up the signal the same way the PC Card does?
PlatinumGold
23,168
how? what is your question exactly?
you realize of course that EVDO is an extension of CDMA2000. only verizon and sprint use this technology in the US right now.
but the signal itself is nothing without a server that authenticates you and allows you to access the internet.
you might be able to get a usb receiver of EVDO signal but how would you authenticate to either verizons or sprints network without having an account with them?
archcommus
8,115
No I would, I'm just asking if there's a way to pick up the signal for a desktop the same way the PC Card does for your laptop.
Goosemaster
48,775
NO.
That siad, you can get a PC CARD-to PCI adapter (if you don't ahvea laptop), pay $60/month, and get wireless internet:D
archcommus
8,115
NO.
Thaaaat's what I was thinking.
Unfortunately, it clearly states in their TOS that it's only allowed to be used for internet and email. :(
PlatinumGold
23,168
NO.
well, would you really want to download files at 600 to 800 kb/s? it's great for browsing but really is slow for downloading files.
Goosemaster
48,775
NO.
according to what I've heard on edgadget, this one guy tried bitorrent on it, used 300MB or so, and got a $x000 bill :laugh:
I'm sure it is fine with a pc if you stick to light browsing
archcommus
8,115
NO.
800 Kbps is 100 KB/sec, I could deal with that.
But rather pointless as what it restricts is exactly what I'd want it for.
Damn I need to find a decent wireless broadband provider.
mwtgg
10,491
Campus network not so hot, eh?
archcommus
8,115
You are correct, sir.
NutBucket
27,154
635
NO.
WTH? I'm guessing he must have connected his phone to a laptop. If you buy a data plan then its unlimited, period. If you use your phone to surf via a laptop then over useage can and most likely will be charged.
mwtgg
10,491
In what ways?
archcommus
8,115
In what ways?
No ports are open except for 80 and 5190 (AIM). Not one other.
PlatinumGold
23,168
NO.
or he was on a limited data plan. ;)
mzkhadir
9,509
NO.
do you know what the limit is on upload/download
mwtgg
10,491
In what ways?
What are you looking to do? Also, why can't you get service from Comcast?
archcommus
8,115
NO.
The plan is called "unlimited" BUT you cannot download games, movies, or music, or use P2P.
mzkhadir
9,509
In what ways?
did you try putting a sniffer on the network or would that get you into trouble
archcommus
8,115
In what ways?
Looking to: use POP3, FTP, Steam, video conferencing.
Can't get ANY cable or DSL service in my dorm apparently because of the physical infrastructure of the cable and phone lines. Service can't be provided to one room.
