Krakn3Dfx
I have a Sony Vaio PCG-GRV680. I friend passed it on to me because it would only boot 1 out of every 5 or 6 attempts, and then only with 256MB of RAM. I started to troubleshoot it, then googled a little, and found that the sodimm connections to the mobo were known to be faulty. As a test, I pressed the RAM up against the board while I booted, and lo and behold, it booted with 512MB every time, which was what it was supposed to be. I took a couple of plastic pieces that I got from cans of compressed air and put them on top of the RAM and then pushed the cover down against it and screwed it in. Laptop works fine most of the time now, except it has some pretty severe heating issues as well, so it hangs sometimes from overheating, even if the internal fan is running at max speed. I blew it out, opened everything up, and checked it out, but no luck, still the same. CPU is a P4 2.6GHz, so obviously, it's not going to be a cool running laptop, but it burns like Sol even if I'm just web browsing. I had to do a clean format of it, and as such there's no real software cooling solution running. I can probably dl something from Sony's support site, but when you go looking for anything on their site, it gives you like 50,000 things to choose from, and I just haven't had the time or inclination to spend more time on it. As noted previously, the battery life on this thing is also horribly short, again, probably due to a CPU that needs massive amounts of power to run.
Needless to say, I like my Dell Latitude D800 w/ Pentium M 1.8GHz a lot more, and I would never buy a Sony Vaio based on my experiences with this one. Sony always has big ideas, but they seem to often have very little followthrough or support.
