Question V-ray 6 / Corona benchmarks
Abwx
11,780
4,689
EDIT: Also, they seem to be doing a 10 min stress test.
This change nothing since they also do 10mn for the full 16 cores and get a score that dont match the 4C one.
I you look at their alledged 4C result and multiply by 1.25 for a 5GHz frequency, 4x for the 16 cores count and 1.32x for SMT this would hardly hit 43k points, yet their 16C result is more or less accurate, if you downscale it by the three factors above you get 47773/6.6 = 7238 pts for 4C/4T/4GHz.
Such a big discrepancy can not be hasardous, Zen 5 4C/4T actual result being 12.3% higher than their made up score.
Reactions: lightmanek
Det0x
1,421
4,812
Sample size of one run
*edit*
See that my thrown together memory settings for the 4-core runs were not fully optimized, so maybe a few more points left in the tank
*edit*
4cores / 4 threads: SMT disabled
4cores / 8 threads: SMT enabled
And just for fun, a vray 5090 run :)
LightningZ71
2,129
2,570
Test the scaling with all the physical cores enabled. SMT tends to thrash the L3 quite a bit when all cores are fully enabled.
Det0x
1,421
4,812
Maybe i will update my score when i got the time
This was done on older lower performing agesa
And a newer Corona 10 benchmark-run as a bonus
(this benchmark seems to scale with memory amount)
Updated with some 9950X3D (ES) numbers
Corona = 18429514 points
Vray = 61379 points
Also did a run in passmark = 20463.6 points
Saw i forgot to screenshot the memory + cpu tab, so had to rerun one more time.
16,812
Stock (no PBO anything), DDR5-7200C34 FCLK 2133 UCLK 1800 Windows Ultimate Power Plan
More benchmarks here: https://forums.anandtech.com/threads/zen-5-builders-thread.2619706/post-41432630
I have a plebian mATX mobo which doesn't have overclock failure recovery and getting it to boot after failure is unpredictable so I'm gonna use it for a while at these non-optimal settings until I am ready to mess with it more.
Reactions: lightmanek and 511
16,812
Going to try something stupid and desperate tomorrow, without touching the insides or fiddling with BIOS options.
OK wait. Maybe I should just say what I'm going to try in case someone can successfully dissuade me from trying something really stupid.
I'm gonna put the case directly in the flow of the airconditioner's cool air. The back of the case where the backside of the mobo is, was unusually hot even after shutting down the PC.
If I put it there and keep it there a while before turning it on, what are the chances of moisture buildup on the inside?
