VirtualLarry
troublesome... at least my primary desktops are wired.
Usually have to upload it to each AP with SSH then run a script that applies it. Not so much that it's hard, just I always forget the exact steps so end up spending some time fidding around. I don't see any option in the controller to upgrade, but probably have to upgrade the controller too. Think I had to last time as it would not pickup the AP.
Upon quick google search I don't think they have the fix out yet, they are still testing, so I'll probably wait a bit before I do an upgrade.
I guarantee you your local wifi is way more 'secure' and less likely to be 'hacked' than all those places you order stuff from every day that keep all your information. Sometimes I really like living in the middle of nowhere by old people. I don't have to worry about all this fear mongering.
Given their wonderful history with security updates, I'll bet that Verizon will recommend disabling Wi-Fi on your phone and upgrading your data plan to "patch" this issue 🙂
This is thee very reason I use my phone for calls and texting only, maybe a pic or two. I have no financial anything on my phone. No banking app or credit card numbers or pay apps
I'm a bit confused, what exactly needs to be patched (Aside from the router obviously)
For example, if someone has an electronic lock on their door that connected to Wifi, will that need to be patched? If so, what would they patch? The Firmware?
As far as a desktop computer - someone mentioned windows released an update - I thought the fix would be a firmware or driver update for your wireless card?
Go wired, or restrict your WiFi antennae power to not penetrate your external walls. Otherwise no, needs to be patched on AP and clients.Is there anything that should be done to minimize risk for home networks until updated firmware for our routers get released? MAC Filtering will make any difference?
Are transactions for https:// sites on devices connected via WPA2 still 'safe'?
all this talk about home routers, do you guys live in apartment buildings or townhouses? I would be more worried about connecting to wifi at say McDonalds than at home.
https itself is safe (by various definitions of safe), depending on the implementation of it. Having said that, over 50% of implementation methods are likely insecure. In addition, many pseduo-common internal protocols used between hosts on a localized network aren't secure (by nature, weren't designed that way), and can pretty easily lead to some kind of root-level access given enough time.Are transactions for https:// sites on devices connected via WPA2 still 'safe'?
