Using two power supplies?
mi1stormilst
1,640
How can I use an additional power supply to power my SLI set up? I have one in the case running all my drives and mobo, I would like to use an extra PSU to just power the SLI setup. How do I ground the PSU so it will turn on without being plugged into the MOBO?
Kakumba
610
ummm, the green and one other wire near the middle on the main power connector.. I forgot right now, cant remember where I found that info.
Basically, you *could* do this, but I would recommend against it, strongly. Just get a new PSU, and use that to power everything. A Silverstone Strider should do it. Its based on the 650W Zeus, but they downrated it because its modular, and uses a 120mm fan for cooling.
Smilin
7,357
connect the green wire to a black (ground).
Be aware that running a PSU without load like this could blow it depending on the PSU.
You should really look into just a single PSU for this. Get a decent one and you're set.
I'm running all this on a $99 Hiper R series PSU:
2x 74gig raptors
1x 500gig drive
Dual core 4600
Dual core GPU (7950gx2 - 1gig memory)
2x optical drives
2x 1gig sticks of memory
CPU and 4x case fans
Cold cathode lighting
Several high load USB devices.
