using Remote Desktop on a host w/ no k/v/m: just turn on and connect
thebeyonder
74
I have set up a Remote Desktop connection between a client and a host. it works fine. but I want to be able to turn on the host computer, with no keyboard/mouse/monitor attached, and start the Remote Desktop session.
when I try that, the client computer gets a message:
"The client could not connect to the remote computer.
Remote connections might not be enabled or the computer might be too busy to accept new connections. It is also possible that network problems are preventing your connection.
Please try connecting again later. If the problem continues to occur, contact your administrator."
it's not a network issue because as soon as the host computer turns on, a balloon pops up on the client saying 100 mbps connected, and I can run cmd \\hostcomputer and that comes up.
Remote Desktop works if a user has already logged onto the host computer. but I won't be able to do that when I am turning on the host without a keyboard/monitor/mouse.
how do I get Remote Desktop to work on a computer without having a user logging on locally first?
OVerLoRDI
5,490
4
Look into tightvnc. It doesn't care if someone is logged into the machine or not
imagoon
5,199
What did you do to set it up? All of my servers are headless and the connect via terminal services without issue. So does the misc "windows 7" VMs that run stupid "Enterprise APPS!" that only work on Windows 7.... what you're asking about is quite a standard configuration. It would making wonder if you missed a step setting it up or something unrelated is actually breaking it.
thebeyonder
74
thank you for the suggestion about tightvnc, but I would rather use the built-in Windows features to keep it simple.
I don't know of any steps I skipped. Remote Desktop connects and functions like it should as long as a user has logged into the host computer first.
there are no BIOS errors. I have the host BIOS set up to not stop on any errors, and Windows is set to "shut down" when the power button is pressed. so it does start up and shut down with no keyboard, monitor or mouse. I can connect through the network and bring up \\hostcomputer. the only problem I am having is Remote Desktop not connecting because a user has not logged in first.
I tested all this with a monitor before I tried it without a monitor. that's how I know what the issue is. Remote Desktop will not connect unless a user has logged on first. even logging on as Guest will make it start working. the user can just log on then log off and RD starts working. unless you do that, it won't connect.
thebeyonder
74
you are doing what I'm trying to do. could you post a copy of Local Policies/ User Rights Assignment and Security Options? right click, export list...
imagoon
5,199
Slightly sanitized.
Code:
Policy	Security Setting
Access Credential Manager as a trusted caller
Access this computer from the network	Everyone,Administrators,Users,Backup Operators
Act as part of the operating system
Add workstations to domain
Adjust memory quotas for a process	LOCAL SERVICE,NETWORK SERVICE,Administrators
Allow log on locally	Guest,Administrators,Users,Backup Operators
Allow log on through Remote Desktop Services	Administrators,Remote Desktop Users
Back up files and directories	Administrators,Backup Operators
Bypass traverse checking	Everyone,LOCAL SERVICE,NETWORK SERVICE,Administrators,Users,Backup Operators
Change the system time	LOCAL SERVICE,Administrators
Change the time zone	LOCAL SERVICE,Administrators,Users
Create a pagefile	Administrators
Create a token object
Create global objects	LOCAL SERVICE,NETWORK SERVICE,Administrators,SERVICE
Create permanent shared objects
Create symbolic links	Administrators
Debug programs	Administrators
Deny access to this computer from the network	Guest
Deny log on as a batch job	*S-1-5-21-2470946059-3806569667-983490619-1002
Deny log on as a service
Deny log on locally	*S-1-5-21-2470946059-3806569667-983490619-1002,Guest
Deny log on through Remote Desktop Services
Enable computer and user accounts to be trusted for delegation
Force shutdown from a remote system	Administrators
Generate security audits	LOCAL SERVICE,NETWORK SERVICE
Impersonate a client after authentication	LOCAL SERVICE,NETWORK SERVICE,Administrators,SERVICE
Increase a process working set	Users
Increase scheduling priority	Administrators
Load and unload device drivers	Administrators
Lock pages in memory
Log on as a batch job	Administrators,Backup Operators,Performance Log Users
Log on as a service	{userdomain}\{useraccount},{useraccount},NT SERVICE\ALL SERVICES
Manage auditing and security log	Administrators
Modify an object label
Modify firmware environment values	Administrators
Perform volume maintenance tasks	Administrators
Profile single process	Administrators
Profile system performance	Administrators,NT SERVICE\WdiServiceHost
Remove computer from docking station	Administrators,Users
Replace a process level token	LOCAL SERVICE,NETWORK SERVICE
Restore files and directories	Administrators,Backup Operators
Shut down the system	Administrators,Users,Backup Operators
Synchronize directory service data
Take ownership of files or other objects	Administrators
heymrdj
3,999
63
Is this host system wireless? If it is then the wireless utitily probably isn't starting until a user logs in. You have to use the Microsoft Zero-Configuration tool to make it automatically go to a specified wireless network.
If it's not wireless well then nevermind and carry on. :p
imagoon
5,199
I wonder what people in this thread have so against RDP that they feel the need to throw around tons of third party solutions. He asked about RDP, lets stay on topic. RDP is also a decent and powerful solution and is included with the OS.
I am not sure what it is about questions about MS products that gets people to immediately to run to some 3rd party solution. Most of them do work and work quite well once you take a couple of minutes to learn them.
/petpeave
JimKiler
3,561
206
OP, something is amiss, you do not need to login to get RDP to work. I have used it a bunch of times without issue, although i have a keyboard, mouse, and monitor hooked up to mine. Do you have the right access rights? What version of Win 7 do you have Pro/Enterprise or non Pro/enterprise?
I guess you cannot connect to a Home or Starter edition of Win 7:
  • You can connect to computers running Windows 7 Professional, Windows 7 Ultimate, or Windows 7 Enterprise.
  • You can't use Remote Desktop Connection to connect to computers running Windows 7 Starter, Windows 7 Home Basic, or Windows 7 Home Premium.
http://answers.microsoft.com/en-us/...y-run-my/54b37a80-b1c2-41d0-b40f-c8899daa2547
bearxor
6,605
I was trying to catch up on the thread and thinking the same thing. Which version of Windows?
thebeyonder
74
XP Pro.
the user rights should be good because RD does work like it should. as long as any user has logged into the host first.
I will check the Local Policies example, I don't have time right now. also will check Services, maybe a required service doesn't start unless someone logs in?
imagoon
5,199
Actually I would try turning the windows XP firewall off and testing that way. The XP firewall I seem to recall applies rules on login. It is possible RDP is blocked until a user account logs in applies the rule. From there you would need to adjust the system accounts firewall rules.
