I was watching the matrix and I realized that using people to generate electricity would work if done right. Normally we use a heat source like burning coal to boil water then that boiling water drives turbines. Instead of coal, we could use people. Instead of water, we could use a liquid with a boiling point around 30 degrees C. The body heat from the humans boils the liquid and that is what drives the turbines. The efficiency of the system can be increased by injecting the humans with amphetamine. The amphetamine will make them generate a lot more body heat and that would generate more power.
Thoughts?
Thoughts?
