I need to make some wiring harnesses at work for some testing in a hot room. They need to be bundled up every couple of feet with something so that aren't ridiculously a big mess of wire. Now for some I made already I used a couple inches of heatshrink every couple feet. It works fine and its rated to 135° C just its pretty time consuming to use the heatshrink. Zipties would be quickest and effective but every type we got is only rated to 85°. The hot room will be as hot as 105° C. The 3M electrical tape is rated for 105° C.
Ok to use?? Like do they give any leeway, or does it start melting at that temp?
