Using dvi input on 48" projection tv for HD player
Laptop44
Guest
Jan 1, 2007
156
I have an Mitsubishi 48"projection tv a few years old. Excellent picture using cable box for HD programing via component cables . Question is all the new HD dvd players use HDMI
for best picture qualiy. If instead I purchase an upconverting DVD player for 1080P it states best quality using HDMI.
Would a DVI to HDMI converter be ok to use? Or would the component cables be better?
TV has only one DVI input. Using coaxial/optical for audio to receiver so sound is not an issue.
Thanks
Slick5150
8,760
DVI and HDMI carry the exact same signal, so you wouldn't lose any quality at all using a DVI->HDMI cable.
montypythizzle
3,698
For upconverting DVDs you WILL need a digital interface. No upconverting via component since the copyright fags got a dick in their ass.
You can watch HD movies with component however.
