Hi everyone, quick question.
I tried to use my Airport Extreme as a USB hub for my external hard drive, where I keep my itunes library with my music/movies/etc. Unfortunately, it did not work. When I would open iTunes on my computer the links to the files would not work (even though it could see the HD and what the files were), and my AppleTV also couldn't find the files even though it could when it was plugged in to the computer. I did some googling and it turns out this is a common problem with no easy solution.
I'm thinking of getting a cinema display. My question is if I plug my external HD which would have my itunes library, would my macbook air and apple tv be able to find those files, or do you think I would run into the same problem as when I plugged the external HD into the router.
Thanks!
Thanks!
