Originally posted by: rockyct
The item needs to draw 500mA, so anything equal to or greater than 500 mA. In this case, it's the 800 mA adapter.
Exactly. The device will only take what it needs.
Using the 300mA adapter would overload it, and likely cause the adapter to overheat.
It's the same reason you can plug a 4W nightlight into a wall socket capable of delivering 20A (assuming the breaker trips properly
) without any problems, or one of those EL "limegreen" nightlights that only draw a few microamps. The device only takes what it needs.
Voltage is a measure of how much the electrons "want" to move.
Amperage is more of a measure of how many electrons are available to do work.
So if you've got low voltage, but lots of amps, you will get a little bit of power flowing through, but could do so for a long time.
If you've got high voltage, but very low amperage (like an electrostatic spark), then you've got a few electrons that
really want to move. But once they zzzzzt! move across, that's it. Done. There aren't any more available.
High amperage
and high voltage is where you get the damage. Volts * amps = watts. More watts potentially (haha, get it?) means more capacity to do work. Or damage.
