Using a torque wrench to loosen bolts
Jules is correct. There are numerous applications where the bolt is Left Hand Thread instead of the normal Right Hand Thread. Probably also quite often on aircraft.
All I know is the HF torque wrench I bought did not come with a calibration certificate and the CDI torque wrench I just bought did. I feel more confident in the CDI torque wrench.
None of my wrenches came with a cal cert, not even my snap-on. I just took em to work and put em on the checker and to my surprise, the HF ones were more accurate. I used mine to mount a balancer bolt that's reverse threaded and it clicked fine. Granted, mine are somewhat old and some HF stuff has been declining in quality (if it even can!) so YMMV. I just hate the generic "HF IS GARBAGE" assumptions many people always throw out when craftsman (now a days) is just as bad.
EDIT: Oh and to those claiming cheap china tools more easily round off bolt heads, I disagree. I've had more cheap sockets and wrenches round off before the bolt did anymore! I don't know how they can claim this chinese mush metal is "hardened" steel when it's softer than play-doh.
I'm not knocking them too much, I just didn't want to trust my motorcycle engine to a cheap torque wrench. I'd rather spend a little more for a quality tool (and yes, my torque wrench did come with a calibration certificate). If nothing else it gives me some peace of mind.
I bought a set of Harbor Freight deep well impact sockets and have been very pleased with them.
This isn't the one my torque wrench shipped with but it was exactly like this.
I did everything on my car with cheap tools and I flogged it mercilessly. D:
