Hi,
I am using a laptop as a desktop at the moment -
hooked up kb/mouse/monitor to lappy.
When the case is closed [system on] there is no give away [without digging] that the laptop is the computer that is being used.
BUT
I can't play movies on the monitor.
When they are started, the audio is fine, but just a black box where the actual movie should be.
If the laptop case is opened, the monitor on the laptop shows the movie is playing without a problem. Lots of codecs installed. Gspot shows there isn't a problem with individual movies. No clashing of codecs reported.
VERY stable system [xp pro]
I've tried VLC, WMP 9, DIVX player,
It seems to be an issue with using a second monitor [not extended, just as one screen]
When you identify either monitor [lappy or external] it comes up as the primary monitor whether the lappy is open, or not.
The laptop is P4 3ghz with ATI Mobility Radeon 9000. [512MB DDR] fast lappy - desktop replacement.
Thanx in advance.
BUT
Thanx in advance.
