Using 37" Syntax HVS for PC Gaming
Stokes
So here is whats up:
I already have dual montiors for general use and gaming on the main lcd. In February I bought a 37" lcd tv to use primarily for watching tv on and all that. I never hooked it up top the computer or anything like that, but now I have an idea and wanted to see what would be the best way to execute this move.
I'm going to be buying the Logitech Cordless Rumblepad for PC and was thinking of getting some Tiger Woods. I thought what better way to play a game like tiger woods then to be on my 37" lcd tv with a wireless controller and using my computer as the console.
I'd never really buy an xbox 360 or a new ps3 mostly because I game on the PC the most and getting another hardware to game with will most likely not be used like it should be. I believe computer gaming to perform or outperform consoles anyways, but i'm not looking for a debate on that.
Basically i want to be like, I feel like playing tiger woods, load up the game on the computer make a setting change to get it show on the tv (maybe resolution too), and start gaming on the tv and then when I'm done just go back to the comp and turn off the connection back to my normal dual monitors.
So how can I make this kind of hookup with my pc? I already am using my video cards DVI and VGA connectors for the monitors. I could use my computers component out on the video card and use component cables and go over that way. Or is there some sort of video split I could use to allow me to get an extra vga or dvi connector or something.
I'm open for ideas and to spend a little money to get this to work, but I'm talking under $50.
What is the way to do this?
Originally posted by: JonnyBlaze
id say buy a second video card to drive one of your monitors and hook the hdtv to your main video card.
Well, I'd have to be a pretty cheap PCI video card since I don't have an SLI motherboard and its agp. I'd rather not upgrade my motherboard for this. I thought there probably would be some other solutions that didnt involve another graphics card. I have no idea though.
Then the other thing I thought of is sound, if the computer is on the left side of the room and the tv on the other, sound will only be out of the speakers of the comp, unless I can figure out how to use the tv's speakers with the computer.. ideas?
I would suggest either getting a cheap PCI card to drive the 2nd LCD, thus freeing up an output on your main card for the HDTV. The other option would be to pick up a VGA splitter, and use it connect both the 2nd LCD and the HDTV. As far as sound goes, you can get a 3.5mm mini plug to RCA cable. Plug the 3.5mm into your line out connection on the sound card, and plug the RCA cables into the sound input on the HDTV. I would suggest shopping for the cable online, as most stores tend to charge way more then they should. Cablesforless seems to be a decent place.
If you want high quality go for matrox's new 3 screen box it runs around $150 and apparently produces some amazing results.
That is REALLY cool, except for the $$. And I don't need the usage for my lcd tv that, that provides.
I'll look for a splitter and the cables mentioned and try using that. So I'm guessing if I go with what was mentioned for the audio, would I be able to set that in game to have sound output the primary output? or would I have to go everytime and change that in windows?
Any other good ways to do what Im thinking of?
