- Nov 16, 2006
- 557
- 0
- 0
I asked a while back for how to test used 30" LCD's coz I was looking at a couple of LCD's locally. Thanks for your responses.
Now that I have found 2 that have perfect screens, I need help/suggestions in deciding between the two.
1) HP LP3065: The seller bought it refurbished from a lab, and there a scratch on the back of the monitor. Screen was fine though. The seller seemed like someone who knows "how to use a monitor". I know for a fact that he has used the monitor a fair bit playing poker. He's selling it for $500 local pickup.
2) Dell 3007WFP: The seller bought it new. The monitor is out of warranty now (just like the HP). He's selling the monitor because he's planning to use his macbook pro exclusively. He was a professional guy ~30yrs, and it seemed like he mainly used the monitor for spreadsheet work and movies. $600 local pickup.
Is the Dell 3007WFP worth the extra $100 since it was bought new? Or should I just keep the amount I invest to the minimum coz if the monitor fails the next day I'll have no recourse? I was thinking if the Dell was the HC version, it would be an easy choice but now I'm a bit confused.
Hi,
I'm going to go check out 2 used monitors tomorrow morning. First one the Dell 3007 (not sure if its the HC version yet), and the other the HP LP3065. Both are out of warranty, but the HP owner bought it refurbished (hence its costing me $100 less for me).
What all should I look for in the monitor? I mean the simple things I know are:
- check for back light bleeding with a full black background and dimmed external lights
- flash different colors to check for dead/stuck pixels!
- what else?
Any help is appreciated.
Also if you have any other opinions about these monitors, please do share!
Thanks a lot
Hi,
- what else?
Thanks a lot
