Intel sells a hypervisor called Memory Drive Technology that allows Optane SSDs to be used in a RAM-like fashion by telling the guest OS that the amount of RAM present is roughly the actual RAM capacity plus about 3/4 of the Optane SSD capacity. I'm not sure what it's doing under the hood that is any better than just using the Optane SSDs as swap devices.
