Question USB-C or not for 27" 4k monitor?
oboeguy
My 24" 1080p monitor is badly in need of an upgrade. I'm ready to upgrade to a 27" 4k display. USB-C seems like it could future-proof it for a while (I buy new monitors very rarely -- I've had all of two over the last maybe 17 years?). Worth the trouble of finding one? Thanks, and generally happy to receive recommendations -- I use it mostly for work: writing code and such so a gaming refresh rate is not high on my list of desiderata.
Edit: to be clear, I'm largely looking at the USB-C question for future-proofing, per my history of buy and hold, so to speak. 🙂
Is it for display input or just as a USB extension?
That's what I want to know. If it's just for more USB ports, just buy a (relatively) inexpensive USB hub (they make them with Type-C connections these days now too), for $20-30-40, and put it on your desk.
USB Type-C premium on this model is $130. Ugh.
If that's not used for display input, then that's quite the premium. You could buy 3-4 USB Type-C hubs for that price, to put on your desk. 😛
If you go with a 30" or larger screen I suggest a curved one.
Well, for me at least, it's easier to fit on the desk if it's a "flat" screen, rather than "curved". YMMV.
I also do more productivity than gaming these days, so the "gaming immersion factor" of a "curved screen" isn't so much for me personally.
If someone does mostly gaming, then yeah, would agree with you, with a caveat that they need to be sitting the "proper" distance away from the screen, to get the best effect of the curvature.
I thought a USB hub is even cheaper than that. For $130 it'd better be something else.
At 30" and larger it is difficult to see everything on screen without moving head. I have a 32" UHD monitor sitting in front of me and that is one thing I wish I knew before I purchased this one.
4K monitors came down in price a lot but for whatever reason USB Type-C ports seem to command a very high premium. I have no idea why. Is it for display input or just as a USB extension?
Anyhow these are LG line-ups.
https://www.amazon.com/dp/B07MKT1W6...colid=2VUOF37AAJC1H&ref_=lv_ov_lig_dp_it&th=1
The idea is future-proofing. I don't expect I'll buy another one for many years. Am I thinking too hard about it? And yeah, the premium on them is pretty crazy right now!
