US 2012 Tax Brackets - Why and what needs to change
Attic
4,282
Pic taken from http://en.wikipedia.org/wiki/Tax_bracket#2012_Tax_Brackets
So from the 66% jump (15% to 25%) brackets is what stands out to me. Bigtime. That's the largest jump between brackets and it lands squarely on middle class. The brackets above the 25% point pinch down to smaller increases so why are we locked into the current rate structure that doesn't appear to make any sense for the middle class. In the lower incomes we see the 66% rate increase, but in higher incomes we see down to a less than 10% rate increase between brackets? In a time when cost of living is going up up up, the big rate jump middle class is going to starve a lot of folks from available discretionary spending while the higher brackets are giving more discetionary spending money.
Other standout look is why does the brackets end at 388k? What's the hold up to adding another higher bracket for higher earners. Currently the folks above 388K get to enjoy the leverage of the vote from those earning between 388k and infinity. Why not put in a bracket at 500k or a million so that any hold up to those brackets being implemented or increased would not enjoy the backing of folks between 388k and 500k, or 388k and 1M? Looks like the very high earners get to enjoy a tax structure that ends at 388k and get the benefit of being catered to by a vote that may change if the tax inceases were leveied at 500k or 1M+ as opposed to 388k where certainly more people would be against it a rate increase.
I believe taxes need to be lowered across the board or remove double taxation and worse and fees that are crushing folks when they need to spend $$$ they've already been taxed on, but the lowereing would need to be 66% lower for the brackets in question and 10% or less lower for high income brackets otherwise or we would still shifting money to the top. The 20% across the board from Romney while in principle I agree with I think misses the method to deliver a promising result for the nation. Of course if you can deliver the tax break to the top, then how about shifting the tax brackets so it starts of slowly increasing and grows to faster increases at the top instead of rapidly increasing at low wages and flattening out at high wages?
DCal430
6,020
9
FYI this is the bracket if the bush cut extension passes, if it fails it will be higher for all.
nehalem256
15,669
8
Eliminate "Head of household" filing status
Introduce a 0% tax bracket and eliminate standard deduction and exemption.
DaveSimmons
40,730
670
Maybe a small increase to something like 42-45% above $800K - $1M. That will hit CEOs, but many of the rich like Romney have capital gains and dividends rather than wages.
Increase capital gains taxes from the current Bush rate of 15% to a compromise rate of (pulling number from hat) 20%.
That will still make investment income attractive, but will hit the rich like Romney a lot harder than the middle class.
We need both tax increases and spending cuts to pay off our national credit card debt.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
That's your usual beatdown on single custodial parents, mostly women, also their children- standard misogyny from you.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Brackets don't tell the whole story, not by a longshot. If we look at effective tax rates, there's no big jump at all, so there must be other factors compensating for the perceived discrepancy- table 8-
http://taxfoundation.org/article/summary-latest-federal-individual-income-tax-data-0
that's 2009, which is likely little different from today. The one thing they don't break out is the rate for those in the top 5% but below the top 1%, which is likely much less than the 20% rate for the top 5% combined.
Once in the top 5%, that's not exactly "middle class", anyway, considering it's ~5X that of the 50th percentile, the median...
Notice the top .1%, which is where low rates on investment income really come into play. They barely pay more than people in the rest of the top 1%...
Attic
4,282
Works great until you get millions for families that are hit hard because of it. Politicians don't have the guts to try it (unless under disguise of something else).
Part of the issue would point to stagnant wages as we desperately need to find a way to get incomes up for tax revenue as well as family needs. I think getting wages up comes from tax relief not more tax burden, but whatever works needs to get implemented. Current tax scheme is certainly broken from what i've seen.
Where the 0% tax bracket is placed would be signficant in where a families tax burden would be pre and post such a change. We'd have to see the 30-45k rate remain largely unchanged or bettered (i think that's achievable) while delivering more tax revenue from higher brackets and or folks reaping to much advantage from deductions. Recieving more money from government that was paid in would have to stop for the lowest earners.
Attic
4,282
Well the fact that the wealthy and ultra weathly get to "earn" huge amounts through investments while paying low low tax on it is clearly an issue and transfers a lot of the wealth of a succesful economy to the top.
For anyone providing income where >50% is from investments, tax the investments in bracketed form otherwise tax it at 15%. It's perverse that the wealthiest get this grin of huge incomes paying 10-15%
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
I'd make it simpler than that. Reduce corporate income tax to less than 5%, then tax all income at current rates regardless of source. Give long term investors a break of 1%/yr held on capital gains, with a max credit of 10%. Disallow holding back of profits in offshore subsidiaries.
Corporate entities would make America their home in droves, because that would be very good for corporations, and the govt would get their revenue out of investors, and out of corporate employees in this country.
Engineer
701
I actually like that plan. I could vote for someone who would actually run on it and "try" to get it passed.
JTsyo
12,031
1,131
capital gains - 15% up to $350K then same as your income tax rate for anything over.
nehalem256
15,669
8
Its called making women pay their fair share. Although apparently treating women as equals counts as misogyny according to liberals.
EDIT: There are already plenty of tax breaks for parents. Why should single parents get special extra tax breaks? It does not seem like something we should be encouraging.
If you use reasonable numbers for inflation and average capital appreciation you get a 35% equivalent rate of 17.5-21%. You should introduce more LTCG brackets like for regular income with the top rate at 21%, and the other brackets adjusted accordingly.
Zargon
12,218
I might lower it to say 178 for single, 217 for joint to match the top of the 28% tax bracket....just to not have MORE numbers to worry about in taxes :p
but yeah, I always felt capital gains should atleast be tiered once
the DRIZZLE
2,956
There is actually fairly broad support on this forum for both the left on the right for this type of tax reform. I'm on board except I'd like to see it accompanied by a flattening of the brackets, and a elimination of most deductions.
BoberFett
9
I'm not entirely opposed to something like that. Doesn't destroy LTCG like many fools seem to want, while lowering corporate taxes which some people still don't understand is a tax on consumers.
I'd certainly be interested to see at least a rough estimate of federal revenues, assuming all else was equal.
BurnItDwn
26,350
1,860
Do not separate capital gains from Earned Income. Tax them at the same rates.
Create a minimum of 3% of taxable income that applies to everybody who earns more than 10K.
Brackets maybe something like this?
0-25K 10%
25-50K 15%
50-100k 20%
100k-200k 25%
200k-400k 30%
400k-800k 35%
800k-1.6m 40%
1.6m-3.2m 45%
3.2m+ 50%
xBiffx
8,232
0-25K 10%
25-50K 15%
50-100k 20%
100k-200k 25%
200k-400k 30%
400k-800k 35%
800k-1.6m 40%
1.6m-3.2m 45%
3.2m+ 50%
Complicate much?
HomerJS
39,180
32,589
How about a cap on all deductions except medical at 200K. Would give back a little fairness to the middle class.
bfdd
13,312
Why are some of you treating people so unequally? Why do you promote divide and inequality? Lol at all the "fairness" bring thrown around. You're just trying to set the OK limit at which the government can forcibly take property and you can't even do that without coming up with imaginary reasons you should be treated differently.
xBiffx
8,232
How about we just eliminate all deductions aside from medical expenses exceeding a % of income. That is the only one that seems not to be choice driven.
dank69
37,258
32,808
I would think that owning a home would be good for the economy. You don't see a lot of renters down at Home Depot every weekend picking up supplies for their latest home improvement project.
child of wonder
8,307
176
I'd rather the government didn't prop up certain parts of the economy like that. It makes it nearly impossible to withdraw the funding because everyone becomes accustomed to it and no one wants to deal with the pain of ending it.
