MovingTarget
- Jun 22, 2003
- 9,002
- 115
- 106
Every house with more than 1 restroom should be equipped with a urinal. Water savings and proper height FTW!
It is acceptable for you not to stand up, but it is still required that you aim!What if you are already pooping and you start to pee.
It is not an aim problem, it is the splash problem. A solution of pee and water splashes up and a portion of that ends up on the floor or wherever. No matter for the majority of you still living in mommy's basement:awe:Are you guys' aim really that bad? Unless you are completely inebriated/drowsy, are incontinent, or are female, then aim shouldn't be an issue.
repost. the last time this was brought up i was shocked by how many man sit to piss. i mean what the fuck is wrong with you?
and I could be so drunk to the point I can barely stand, but I still stand, or hover to a degree, or more accurately I lean. Lean toward whatever wall is nearest, throw hand out there, and support myself - and then try and aim.![]()
wtf? turn on the damn lights. What is wrong with you?Poll
I stand most of the time. Though, during my night time visits to the washroom I sit to avoid misfire.
This doesn't even make sense. If I sit down with a boner, it sits on top of the seat and piss would hit the wall. If I put it down between my legs before sitting then it would likely touch the water. Are you using some kind of magic toilet with a really low water level?If you sit to pee for any other reason than you have a massive erection and are trying to piss before boning your SO to avoid later prostate discomfort....
You're supposed to be FACING THE TOILET when you piss. Don't just point in any random direction. wtf is wrong with you people?at home I sit .. don't like to clean up piss
Why would you sit to pee with a boner?
http://www.gadgetfind.com/flushlight.htmlwtf? turn on the damn lights. What is wrong with you?
I got one last year as part of a woot deal. Of course, any nightlight would do.
That's what she said!After 39 years, I can piss pretty accurately without a fucking light. You are standing if front of a circle about 12"+ in diameter. It's not that hard.
