Urgent help required please
ant80
411
I have 13 nodes, each connected to several others, both simplex and duplex connections are seen. I can't draw using word because I need to relocate each node, and after relocation, I am forced to redraw the connections. I only have Microsoft Office Professional. Is there any other software I can use to draw this connection? Thanks.
- ant80
jkoon
158
In the past I have used Microsoft Visio (that?s what I have at work). I would imagine there are other alternatives though.
Perhaps look for some type of opensource project.
Also, I?m not sure but I think OpenOffice comes with some type of flowchart program that should do the trick. Ok, I said that then decided that I would look it up, it does:
http://www.openoffice.org/product2/draw.html
So yea, download and install openoffice (its free).
ant80
411
Thank you. You are a GOD.
