Hi all,
I have an ECS K7VTA3 system board (1.0c BIOS). The board has an option to type a password on the keyboard before it powers on. I set a password to do this (it is on a different screen than admin/user password).
Now when I try to turn the system on by typing the password, as well as pressing the actual power button on the case, the system does not power on. Normally (of course) the system powered on when I pressed the button on the case - it also powered on when I had it set to "press any key on keyboard" to power on. Immediatly after I turned the system off to try the password on key board power on, however, this occured and I can not turn on the computer.
I did not loose the password, and I am sure I am typing it on the keyboard correctly. (it is a password I use frequently) Unfortunately it is not working.
All I am doing is typing the password on the keyboard. Is this the correct thing for me to do, or am I supposed to do more? If so the manual does not specify what to do. (I tried pressing enter after I typed it as well)
Also, I have tried changing the jumper to clear CMOS with no result.
Please don't tell me I ruined the board. ;x
I would very much appreciate any help someone can give me!
Thank you very much!
Mike
Mike
